How does memory addressing with integrated video cards work
AncientPC
1,369
If I am running a 32b OS I have 4GB of address space available. Assuming 3GB of system RAM and a 1GB discrete video card RAM I am using 100% of available address space.
If I have 4GB system RAM and an integrated video card, how much of the address space is used by the video card? Does it fluctuate? How can I tell within XP / Vista / Ubuntu how much memory the integrated card is using?
Also, assuming an integrated video card and a FSB the latency between video and RAM is another contributing factor to lower integrated video card performance vs discrete, right?
ViRGE
Elite Member, Moderator Emeritus
167
You'll have anywhere between 3.3GB and 3.7GB available, depending on what other devices are present in the system. AFAIK there's no easy way to tell quite how much address space a single device is using.
Nothinman
30,672
That depends on the video card.
It varies per-card but it doesn't fluctuate at runtime.
Steve
15,945
11
How do you know? Is this just a random range of numbers you're pulling out?
Text - does this help?
Nothinman
30,672
Pretty much, but it's where most people end up falling so it's a good initial guess.
Steve
15,945
11
Yeah, I didn't mean to lash out, I just get disgusted when some people throw numbers around and make it sound definite. I know ViRGE wasn't intending that.
