The world?s first 32-bit and 64-bit processor compatible with the x86 architecture, the AMD Opteron processor is based on AMD64 technology with Direct Connect Architecture. Direct Connect Architecture helps eliminate the bottlenecks inherent in a front-side bus by directly connecting the processors, the memory controller and the I/O to the central processor unit to enable improved overall system performance and efficiency. AMD was the first to announce the completion of an x86-based dual-core processor design and the first to demonstrate an x86-based dual-core processor for 32? and 64-bit computing. As more solution providers join the AMD64 ecosystem, the industry is approaching the day when 32-bit-only systems will become obsolete.
http://www.hypertransport.org/tech/index.cfm
http://www.ukgamer.com/article.php4?id=143&page=1
* HyperTransport technology is a high-speed, low latency, point-to-point link designed to increase the communication speed between integrated circuits in computers, servers, embedded systems, and networking and telecommunications equipment up to 48 times faster than some existing technologies.
* HyperTransport technology helps reduce the number of buses in a system, which can reduce system bottlenecks and enable today's faster microprocessors to use system memory more efficiently in high-end multiprocessor systems.
* HyperTransport technology is designed to:
o Provide significantly more bandwidth than current technologies
o Use low-latency responses and low pin counts
o Maintain compatibility with legacy PC buses while being extensible to new SNA (Systems Network Architecture) buses.
o Appear transparent to operating systems and offer little impact on peripheral drivers.
* HyperTransport technology was invented at AMD with contributions from industry partners and is managed and licensed by the HyperTransport Technology Consortium, a Texas non-profit corporation. The full specification and more information about HyperTransport technology can be found at HyperTransport.org.
HyperTransport is a licensed trademark of the HyperTransport Technology Consortium.
Bonus http://the-inquirer.net/?article=1685http://the-inquirer.net/?article=1685
read How Intel wants to copy this as well...
Intel chips will soon be known as AMD clones....
