I'm just curious. I'm having a tough time deciding between the 9800PRO and the 9800PRO AIW. The only thing that's keeping me from making the decision to just go with the AIW is that the 9800PRO has dual monitor support and the AIW does not.
That being said.. How does the dual monitor work exactly? Are both monitors on at the same time or can you just run one at a time? If you can run both monitors at a time, can you have something different on both monitors or would it be like an expanded desktop?
Someone has already mentioned that there is no dual dvi support, so you'd either have to run both monitors in VGA (one with a DVI to VGA adapater) or run the one with DVI and the other with VGA.
One of the things that I thought about doing was hooking up my 21" CRT for gaming and videos and then hook up my 18" LCD on the DVI for everything else. Would this be a good set up and would it work the way that I want it to? That is running a game on the CRT while I have the desktop free on the LCD?
TIA,
Sal
TIA,
Sal
