Originally posted by: bcoupland
I have noticed that some high-end monitors have a feature called dual-link DVI, presumably with two
DVI connections to one monitor. How does this work. Just Curious.
Dual-link DVI is one DVI connector with twice the usual bandwidth. It uses all 24 pins of the connector. (Standard single-link DVI does not.)Originally posted by: bcoupland
It's 2560x1600.Originally posted by: bcoupland
The new Apple is something like 2560x1200 and requires a special
6800Ultra to drive it. Apple also says that it will run two 30" displays
for a resolution of 5120x1200. That poor, poor video card.
Single. It's good for up to 1920x1080 @ 60 Hz. Actually, 1920x1200 @ 60 Hz seems to work fine.Originally posted by: CSMR
Are the DVIs on most video cards (9x00 etc.) dual link or single?
Yes, but they are uncommon and very expensive.Originally posted by: BDSM
Hey.. Are there any gfx-cards for the PC that support Dual link right now?
Yes, but they are uncommon and very expensive.And also.. are there any monitors except apple's latest that has this feature?
I think it will be used very often in the future. Monitors are scaling up in terms of DPI because it is now possible to do so with LCD and OLED displays.graphics really isn't my specialty but, aside from dual link being part of the DVI standard as set my Intel guidlines,i really don't think its used often if at all for consumer graphics cards. it seems to be an overkill addition to the standard that will never really be used.
Yeah, but these apple PCs seem to take on a lot of characteristics of workstations as time goes by.Originally posted by: AWhackWhiteBoy
No they aren't! I like squinting! 🙂Originally posted by: Eug
Unfortunately, both OS X and XP are still really best suited for around 100 ppi.
