the bottom of the front bezel is generally open and the case usually sits on some sort of feet, thus the fans will draw it from the bottom of the case....thats my best guess as i dont own that specific case, but my antec and dell case work that way
those fan mounts in the front are jokes. they'd be lucky to pull any air at all through a lousy metal grill, and tiny slit at the bottom of the bezel. not to mention the fan holders generally kill airflow themselves. its dremil time🙂 92mm fit in mine.
