How do you guys organize your papers/documents? I currently have mine in a crumbling expandable folder with old and mismatched folders and I'm looking for a better solution. Any ideas? Something that won't break the bank is preferable – I don't really have *that* much to file.
This. It might take a while to scan everything, but it is WELL worth it. I store any originals docs that I have to keep(car title, SS card, etc) in a lockbox at the bank.
Using a combination of analog and digital for my needs. I'm scanning as much as I can and storing it locally, then I'm backing up to an external HDD and off-site on Drop Box.
For everything that I need hard copies of, I bought a $9 plastic divided binder.
super important stuff like tax documents go into a fire proof document safe
stuff that needs to be saved, i scan it and gmail the file to myself
everything else goes in the garbage
