If you check THGs site ,some of his more recent CPU reviews shows SETI benchmark WU times ,bear in mind the P4HT times are for the number of WU's/day divide by 24hrs ,not the actual WU time
I'm building an Opteron box now (waiting for the parts). It's going to be a Dual 240 with 2GB of PC2700 DDR ECC RAM (1GB per CPU) with 2 80GB Sata Drives raided. THG had a quad Opteron running WU in 34 minutes, but I don't think that was the 240 😛
