Originally posted by: KraziKid
When you pull on the arm, there is a meter that tells you how much torque is being applied. It works from the bending or warping of the arm. This is called torque.
yeah.
Torque Circluar rotational acceleration...sometimes confused with circular tangental acceleration....
Then again I suck @ physics so don't trust me on that one..😀
Don't most of the newer ones have the torque measuring apparatus built into the head of the wrench?Originally posted by: KraziKid
Originally posted by: Nocturnal
Is there a setting on the wrench it self normally where you can set it to say 80lbs of torque? Or whatever the bolt might need?
yep. set it to 80ftlbs, turn it until it clicks, done.
Cool. As far as working on Hondas and what have you would I need to get a metric torque wrench or a regular I dunno US standard torque wrench?
