so in otherwards the T1 is the connection from DTE to DCE? >>
Not exactly. The T1 is the actual circuit from the provider to the customer. The connection from a DTE to a DCE could be from the router to the CSU/DSU or something as simple as from a computer to a hub (depending on if you even consider a hub as a CSU/DSU-like device). IMO a CSU/DSU is basically a modem (ex. a Pairgain w/T1 card).
As found at
CommWeb
(Digital Signal) A classification of digital circuits. The DS technically refers to the rate and format of the signal, while the T designation refers to the equipment providing the signals. In practice, "DS" and "T" are used synonymously; for example, DS1 and T1, DS3 and T3.
T-1 A 1.544 Mbps point-to-point dedicated, digital circuit provided by the telephone companies. The monthly cost is typically based on distance. T1 lines are widely used for private networks as well as interconnections between an organization's PBX or LAN and the telco. The first T1 line was tariffed by AT&T in January 1983. However, starting in the early 1960s, T1 was deployed in intercity trunks by AT&T to improve signal quality and make more efficient use of the network.
A T1 line uses two wire pairs (one for transmit, one for receive) and time division multiplexing (TDM) to interleave 24 64-Kbps voice or data channels. The standard T1 frame is 193 bits long, which holds 24 8-bit voice samples and one synchronization bit with 8,000 frames transmitted per second. T1 is not restricted to digital voice or to 64 Kbps data streams. Channels may be combined and the total 1.544 Mbps capacity can be broken up as required. See DS, T-carrier, bipolar transmission, D4 and ESF.
64 Kbps
T-Carrier Total Speed Channels
T1 1.544 Mbps 24
T2 6.312 Mbps 96
T3 44.736 Mbps 672
Voice/Data
Service Channels Speed
DS0 1 64 Kbps
DS1 24 1.544 Mbps (T1)
DS1C 48 3.152 Mbps (T1C)
DS2 96 6.312 Mbps (T2)
DS3 672 44.736 Mbps (T3)
DS4 4032 274.176 Mbps (T4)
EUROPE (ITU)
Voice
Service Channels Speed (Mbps)
E1 30 2.048
E2 120 8.448
E3 480 34.368
E4 1920 139.264
E5 7680 565.148
SONET CIRCUITS
Service Speed (Mbps)
STS-1 OC1 51.84 (28 DS1s or 1 DS3)
STS-3 OC3 155.52 (3 STS-1s)
STS-3c OC3c 155.52 (concatenated)
STS-12 OC12 622.08 (12 STS-1s, 4 STS-3s)
STS-12c OC12c 622.08 (12 STS-1s, 4 STS-3c's)
STS-48 OC48 2488.32 (48 STS-1s, 16 STS-3s)
so what advantage do you have... not advantage.. .but when do you decide when to use frame-relay opposded to PPP? >>
You would need to base that decision on how your circuit terminates, how your provider has their cirucuits routed, what sort of signaling/framing your CSU/DSU requires, etc. There are many things that can contribute to how your circuit will be made.
For example, my tailend circuit is just a straigh static. Hell a simple default route does what we need it to do. But for our encapsulation we use HDLC (defaults) because that's what our provider has directed us to use (they have a 4000 series we connect to). Thats it.
