How does a softmodem work?
Kalessian
825
12
How does a softmodem work? I mean, what's the rules for most "winmodems".
I want to understand them better because they're giving me problems.
Apparently, they don't use the RAM/CPU cycles in the same way a game or onboard sound does. A more specific question is, then, what is unique about the way a softmodem uses system resources?
imported_Phil
9,837
The DSP process is performed by the CPU, not the modem itself.
(At least, IIRC it's the DSP process)
itachi
390
like phil said.. modulation and demodulation of the signal is performed by the cpu.. winmodems also use a software based controller- it uses the cpu to determine initialization parameters and how to behave when certain events occur.
Peter
9,640
Softmodems work in absolutely the same way as a controllerless sound solution works. The waveforms are generated and analyzed by the system's main CPU, not a dedicated signal processor. Data communication is through a fast, direct chipset connection (faster than PCI) rather than a legacy serial or USB port.
