- Apr 30, 2009
- 3,685
- 0
- 0
Any1 have a video of how the clutch works?
My guess is that the engine is connected to a flywheel, the flywheel can be connected to the tranny via friction between two plates(Is it only friction or is there a teeth mechanism?). So when you step on the clutch, a shaft pulls the clutch back making shifting easier. Does the tranny also stop completely when you pick up the clutch? Also, I hear there is a self lubrication system when the clutch is not in use?
