when it works its great, when nothing can connect at all! and in the past i seem to be able to fix it by randomly toggling some setting in the wireless router (trendnet TEW-431BRP).
i am not sure if it equipment incompatibility, or the stupid router, or air interference.
i tried multiple different vendor wireless adapter clients, the results are not conclusive. so i know its not the clients, but incompatibility may be the case.
i know its not config because a working config would work one day not the next. and when it does work, it stays up as long as i leave the pc on/connected.
with regular ethernet, i can set up a sniffer, but wireless... what do you do when it won't even connect? the survey shows it sees it, but it won't connect to it as if the pw is wrong or something... i don't want to go buy another router if it turns out to be air interference (even with full bar with my signal booster). i am posting this at 6:30am from about 1:30 hour of frustration.
