athrowaway2242
Hey all,
It seems that fans/controllers are a hot mess..
I have three AIO I am looking at for this build.
1: EK Nucleus CR360 https://pcpartpicker.com/product/LR...u-cooler-ek-nucleus-aio-cr360-lux-d-rgb-white
2: arctic freezer ii 360 https://pcpartpicker.com/product/cd...-a-rgb-4882-cfm-liquid-cpu-cooler-acfre00152a
3: lian li galahad trinity 360 https://pcpartpicker.com/product/HH...ty-sl-inf-613-cfm-liquid-cpu-cooler-ga2t36inw
I have heard lots of stories of the galahad dying and pump failure, so was leaning toward EK or arctic. my understanding is they each come with 3 fans. these are standard fans which if mounted normal would be exhaust, but i was planning to swap the fans for reverse blade fans to use as intake.
Now, i know RGB/LCD/fan controllers are not standardized, so based on the research ive done i think i can swap the 3 fans on the AIO for the 3 reverse blade LCD fans. then i could take the 3 arctic or EK fans and use them as top case exhaust fans. then I would use 3 lian li uni fans on the bottom of the case as intake, and one 140mm fan on the rear as exhaust
my question is, what parts/controllers/adapters are needed to make this all work so the computer can control the fans, and also the RGB things. is it even possible across brands? i figured the galahad is simplest solution but also high failure rate has me scared.
i think i need the adapter i linked in the build and the fans come with a controller - not sure if i need anything else for all this to work.
adapter
thank you!
~A
PCPartPicker Part List
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor ($384.98 @ Newegg)
CPU Cooler: EK EK-Nucleus AIO CR360 Lux D-RGB 72 CFM Liquid CPU Cooler ($163.99 @ Amazon)
Motherboard: Gigabyte X670E AORUS PRO X ATX AM5 Motherboard ($279.99 @ Newegg)
Memory: G.Skill Trident Z5 Neo RGB 64 GB (2 x 32 GB) DDR5-6000 CL30 Memory ($219.99 @ Newegg)
Storage: Samsung 990 Pro 4 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($299.99 @ Amazon)
Video Card: Gigabyte AORUS MASTER GeForce RTX 4080 SUPER 16 GB Video Card ($1199.99 @ B&H)
Case: Lian Li O11D EVO RGB ATX Mid Tower Case ($149.97 @ Newegg)
Power Supply: Corsair RM1000x (2021) 1000 W 80+ Gold Certified Fully Modular ATX Power Supply ($123.49 @ Amazon)
Operating System: Microsoft Windows 11 Pro Retail - USB 64-bit ($198.99 @ Newegg)
Case Fan: Lian Li Uni Fan SL-Infinity 72.7 CFM 140 mm Fan ($34.98 @ Adorama)
Case Fan: Lian Li UNI FAN SL-INF Reverse Blade 63.6 CFM 120 mm Fan ($29.27 @ Amazon)
Case Fan: Lian Li UNI FAN TL LCD 120 Reverse Blade 83.4 CFM 120 mm Fans 3-Pack ($136.74 @ Amazon)
Monitor: Samsung Odyssey G9 G93SC 49.0" 5120 x 1440 240 Hz Curved Monitor ($999.99 @ Amazon)
Custom: AsiaHorse 12VHPWR Cable Extension Kit, 16AWG 16Pin PSU Cable Extension Kit Soft Braided Sleeved Cables for 24pin ATX /4+4pin EPS /12+4pin, 30CM Length with Cable Combs (White) ($29.99 @ Amazon)
Custom: Lian-Li Universal 4- Slots Vertical GPU kit (White, VG4-4-V2W) ($60.00)
Custom: fan wire adapter ($22.00)
Total: $4392.89
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2024-07-22 12:52 EDT-0400
adapter
thank you!
~A
Total: $4392.89
