How do you stop a nosy (slapping) garage door chain?
lokiju
18,526
When I open my garage door, the chain slaps the rail and makes a loud noise.
What can be done to stop it from doing that?
Howard
47,982
10
There's a roller link somewhere on the chain that's held to the adjacent links with a C-clip that can be popped out with needle nose pliers. Once you get that off, you can disassemble as much of the chain as you need to. When you put the clip back on (the link with the removable clip is called the master link), make sure that the end with the opening faces away from the direction of travel, just to be on the safe side.
EDIT: Is there anything that adjusts the tension on the chain? If so, just set that up then.
akshatp
8,349
Replace your opener with a Belt Drive...
Its 90% quieter... I can close both my doors at the same time and you cant even hear it in the Living Room which is just next to the garage.
Belt Drive FTW
Squisher
21,204
66
Originally posted by: meltdown75
Originally posted by: HomeBrewerDude
is there an adjustment set screw that can be used to tighten the chain?
there is on mine.
Originally posted by: Baloo
Adjust the tension on the chain. Look for a long threaded bolt inline with the chain, tighten it.
:thumbsup::thumbsup::thumbsup:
lokiju
18,526
there is on mine.
I'll check it out and see.
I wouldn't have even known what to look for. Thanks :beer:
