how do you set up lan with a hub
Fight4Right
Banned
Jul 16, 2001
69
my friend is trying to get me cable from my bro with a linksys hub
but he cant do it he says that they are harder than a router
what should i do?
and whats better for that hub,router,or switch
Damaged
3,020
Unfortunately I'm going to have to interpret what you said, so if I'm wrong you're going to have to explain.my
"friend is trying to get me cable from my bro with a linksys hub"
You're trying to hook into a cable modem via a hub for an internet connection? Yes? If so you're probably going to need some type of software (like ICS in Win98SSE), or some type of device to share the connection (Cable/DSL gateway device (okay, router)).
"but he cant do it he says that they are harder than a router"
Umm, harder in what sense? Because you need something to share the connection? I mean a hub is plug in wires, that's it. There's nothing to configure on the hub itself.
Fight4Right
Banned
Jul 16, 2001
69
yeah ics you say
its just that its installed the lan cards but networking is a a$$
where do i get "ics" from
Damaged
3,020
I don't know dick about ICS, but it's Internet Connection Sharing and it's included with Win98SE.
