How do you right-click and rename a file extension in XP?
Kaido
Feb 14, 2004
51,770
7,322
I'm on an XP Home box and I want to rename file extensions once in awhile without having to use the "see filename extension" setting in Windows. Right now I'm using the dopey way, opening up Command and renaming it through DOS just because it's quicker, but is there an easier way?
oog
1,721
does it work to type the name with quotes? it does for the save-as dialog in something like notepad.
ProviaFan
14,993
Not as far as I can tell from my limited testing with a temporary file on my WinXP Pro desktop. :(
