I used some small, black zip ties that you can find almost anywhere They worked well (even on the bigger fans) but they arent the prettiest things to ever come upon!
Visit some local pc repair shops and ask to purchase the case fan screws .............. they will usually give you some if they don't have them for sale....
Or,..... buy the correct size case fan and make sure it comes w/the screws and maby a 4-pin molex pig tail adapter.....?
I had to put my side fans on with adhesive, because the screw were too small to go through the fan and filter, works for me. But if u ever want to take it off, its gonnabe tuff.
