How do you know if you need a Bigger Power Supply (300 vs. 250)
JJordan
1,069
I am concerned that my power supply is too small, but I have no idea how to check or how to know. I do not have any apparent problems. I am running a pretty generic case with a 250 W ppwer supply. My computer has an Asus CUSL2-C MB, ASUS V7700 32 MB GeForce 2 GTS, SB Live Gamer, 20 gig ATA 100 Quantum HD, 10 gig ATA 33 IBM HD (both 7200 rpm), P3 700E Processor, HP 9350i CD-RW, internal 100 MB Zip Drive and a Kenwood 42x TrueX CD-ROM Drive (and a floppy drive and one case fan. I need one more plug in for the internal zip drive so I was just going to get a $5 splitter and split one as soon as my IDE conroller gets here so I will have a place to plug in the IDE cable and use it.
Whew, see why I am concerned, but again, I do not appear to have any problems or issues. How do you know or test or detrermne if it is OK. I have the ASUS monitoring program but really don't know what I need to be looking at on the voltage. The 5v reading is usually around 4.8 I think. The others seem right on or over what the program says.
Viperoni
11,084
Hmmm...What make is the power supply?
Any specs on it?
It is getting kinda close to the limit, but it should be alright.
Phunktion
2,502
A lot of the crappier 300 watt PSU's are just rebadged 250's anyways.. a 250 is definitely the bare minimum tho for an AMD.. however as long as you don't have over 5 drives and too much fans your PSU should be just fine..
