I have a disturbing amount of faulty ethernet cables. I have 3 that work, 5 that don't. What makes it worse is 3 of the 5 that don't work are 50' cables.
Is there anything I can do to save these cat 5 cables? Should I cut / recrimp the cables? What would be a required, a wire crimper and some plastic phone jacks all available from Radio Shack? Is there anything I can use to run a line test on the wires to make sure they're fine and it's not the phone jacks problem?
On an unrelated matter, I have a generic 5-port switch where only the uplink / 1st port works, but none of the other ports do. Is there anything I can do to test / fix it?
