how do you delete system restore points?
Go to Start/Programs/Accessories/System Tools/Disk Clean-Up. Run Disk Cleanup, and click the tab that says Other Options(?). At thebottom you will see the option to remove all but the latest restore point.
Originally posted by: anarchyreigns
Turn off system restore...then reboot...and they'll be gone.
This is a retarded thing to do. Seriously.
Follow helpmeout's advice instead.
Listen you bag of jizz, you might want to actually know what you're talking about before you go lipping people on a public forum. The easiest way to delete every restore point (not all of them but the most recent...but every single one of them) is to do it the way I described. Do you know why the OP needs them deleted? Did he specify? How do you know he isn't infected with a worm or virus which requires the removal of all restore points in order to effectivly remove said virus/worm?
Shut your mouth...you teenage fool !
