How do you clean your fleshlight?
crab
7,330
19
Damn, with as much as you use yours you've NEVER cleaned the damn thing?
Linux23
11,371
741
Originally posted by: Zim Hosein
Originally posted by: FleshLight
After use, remove the gel insert from the plastic canister and run hot tap water through it to remove fluid deposits. To disinfect use rubbing alcohol.
Towel dry or air dry the gel insert. The gel insert will feel tacky or sticky after washing - this is normal. To restore the original silky feeling of the insert, powder it with cornstarch. Powdering it is not necessary to care for the insert.
Using soap or detergents to clean your gel insert will deteriorate the surface of the gel insert, resulting in a tackier feel.
Some people have asked if we could put a coating on the gel insert to lessen the tackiness. Unfortunately, the coatings that are currently available are toxic and may cause rashes. We consider our customers' health and well-being first, and will not use any substance that is not considered safe in e very way. We are constantly working to improve our products. Once a safe coating is available to us, we will make it available to our customers as well.
To properly re-position the gel insert inside the plastic canister, reach through the small end of the canister and pull the insert down into place.
This product was designed by the manufacturer for single-person use only. Do Not Share! Interactive Life Forms accepts no responsibility for improper or multiple-partner use of this product.
that seems like a lot of work. :(
You could send it to me and I'll clean it with my "special soap".
:Q
:shocked: as well.
illustri
1,490
Originally posted by: CrackRabbit
In an Autoclave. Germ Free every time.
i like the way you think, but hi temp sanitation's liable to damage whatever material the fleshlight's made of, i hear johnson&johnson's got a very good low heat nonirridiation protocol
/ da -- i mean -- thats disguisting
Nov 3, 2004
10,491
22
:Q
Confused
14,166
It was obviously not designed by the Sirius Cybernetics Corporation complaints department!
