ajskydiver
- Jan 7, 2000
- 1,147
- 1
- 86
The current model M-16A2 is an excellent weapon. Why do we need an AK-47 when we have the SAW?
~AJ
~AJ
Isn't the A4 the latest? Or is there just A1 and A2...Originally posted by: Aj_UF
~AJ
Obviously this SOP was conceived for a number of reasons such as errant rounds from misfires going into engines, or even other soldiers in the event of a hard landing.
If you have the opportunity to observe the 101st ABN (Air Assault) during training, you'll see soldiers sit in the jump seats with weapons between their legs and pointed down. Special Ops (Rangers, SF, Delta, etc.) typically bend the rules a bit more.
Bingo. You point the muzzle in the oppositie direction of the engines and drivetrain. Since on most rotary wing aircraft that hardware is topside, that means buttstock up. If they were slung underneath, you'd do the reverse.
As one of those SF guys you're talking about, i can honestly say i never had a crew chief or any of the other flight crew attempt to give me instructions on how to carry my piece. They generally treated us like we were some weird sort of alien lifeform that they found slightly unsettling to have aboard "their aircraft."
On the fly i generally found it comfortable to set the edge of the reserve chute pack tray on the buttstock of my M4, and catch a corner of the seat webbing with my main chute. That way you could make use of gravity and friction to keep everything in place... you could simply lean forward a bit, get comfy, and catch some zzz's. On the go, i'd rest the edge of the buttstock frame on my LBE, generally around the med pouch or whatever was convienient, and simply palm the stock in between the front of the magazine well and delta ring for the handguards.
Originally posted by: Shockwave
For those who asked, the M16 is a damned fine weapon, but she's like a woman. Treat her WELL. It needs to be very clean. Its more accurate then a AK, but, with that increased accuracy comes a dislike for dirt. The AK on the other hand, well, that thing would shoot if ya dropped it in mud for a week. While not as accurate, the AK will shoot and shoot and shoot and shoot. Same with the SKS, the chinese version of the AK. They are very simple weapons without alot of tight tolerances on the machining, so while their accurate enough to be functional, the two things you dont do is snipe with them and clean them.![]()
...and with that comes the greater power of the AK47 over the M16. Typical Russian style, it will be inaccurate, but those shots that do hit do a hell of a lot of damage. Also in jungle warfare, your shot will go a lot further without getting stopped or deflected by brush.
Originally posted by: burnedout
Aj_UF is correct.
Normally during airmobile operations, the crew chiefs of the birds become rather annoyed (read: PO'd) if the soldier's weapon isn't pointed down while in flight. This includes M16s, M60s, M249s, etc.
I was with the 101st before they put the jump seats back in the Blackhawks. We'd typically cram 19-21 soldiers in the cabin sitting on our butts and rucks. Regardless of the amount of soldiers on board, the muzzle of the weapon was still pointed down towards the floor of the aircraft.
Obviously this SOP was conceived for a number of reasons such as errant rounds from misfires going into engines, or even other soldiers in the event of a hard landing. Additionally, the flash suppressor on the muzzle was deemed more dangerous than the butt of the stock in a crash.
This SOP was in effect in 1980. From what a crusty old NCO told me back then, the practice began after Vietnam.
Ah yes, the old M16 vs. AK47 debate. Here is my two cents.
The M4s were deployed during my last couple of years in. They shoot well, although not as accurate as the A2s out past 300M. There is a bit of a learning curve when switching from an A2 to an M4 as well.
Aj_UF is correct.
as far as how the M-16 is being carried in that picture all i can say is i have never seen anybody in a hostile situation carry a weapon like that. We carried the weapon like schmedy said for the same reasons.
