............mAmp.....Watt.....RPM......CFM.......db
Low.....180.0......2.2.......1700.....68.9......30.0
Mid......340.0......4.1.......2100.....86.5......35.5
High.....460.0.....5.5.......2500.....103.8....41.5
(i hope this shows up properly, these are all panaflo 120mm fans)
I'm curious exactly how you are supposed to calculate the new specs when you lower the voltage. Am I supposed to calculate the new wattage drawn and then calculate the RPM for that new wattage, and then draw a rough estimate of the CFM and db for that particular RPM?? (like assuming if the RPM falls between two fans above the CFM/db specs should be between too)??
This logically sounds right but would like to know for certain if using a fan controller might require a diff approach at estimating the noise/airflow. And am I supposed to use simple linear calculations for wattage, like does using 6v instead of the standard 12 means the fan does 1/2 the wattage it normally would use?
So basically if I get a High/H1 fan and run it at 7v, it should draw roughly 3.22w (7v*.460amps), and the CFM and db should fall between the values for the Low and Mid speed panaflo fans?
