How do the UD point system work?
dexvx
Couldnt find anything in a search, but how does the UD point system work out?
My overall is a 110
2.3Ghz P4 gets a 100
512MB Memory gets a 134
.98GB HDD gets a 20
Intel Pro/100 M gets a 121
hmm, lets see if i can do this from memory
cpu = 40%
memory = 30%
HD = 10%
network = 20%
now i think that is right, or kinda close to right.
increase your total HD space available (don't worry it won't affect anything) and it will inflate your total points, even though it has nothing to do with how fast you will complete a WU. you can do this through my devices on the web site.
also i highly recomend doing another DC project in addition to UD if mostly what you care about is the stats, because points are based on how long it takes to complete a WU and not how many, you can run seti, which is a higher priority than UD, and get almost double the out put of one machine.
