How do scopes/aims on guns work?
Cheezeit
3,298
Since the scope is always a little above the barrel, won't your shot always be a little lower than you aimed it at? Won't snipers always have to aim a little up, especially when trying to get a headshot?
Is there some mechanism in the gun to make it exact or do the shooters just have to calculate and compensate?
Just curious and uninformed ;)
SVT Cobra
13,264
you always test and recalibrate a gun on a range at a known exact range when putting on a new scope or barrel
mugs
48,920
46
It's adjusted so that at some specific distance away from the barrel the path of the bullet will cross the straight line from your eye through the scope.
Simpler version: the scope points down a bit.
Cheezeit
3,298
So it would be different everytime for a different range? DO you guys mean the scope and barrel form sort of an "X" at the target?
Cheezeit
3,298
ah I see. Thats just what i just posted asking.
Thanks guys
TheNinja
12,207
Well every distance/range would be aimed slighty different yes. To take into account a) the score and the barrel would for an X and mostly b) a bullet does not travel a straight line like a laser...it is more of an arc.
mooncancook
2,874
50
The scope may be parallel to the barrel, but the reticle makes an angle with the barrel, and the angle is adjustable, and need to be adjustable depending on the distance of the target for an accurate aim.
[edit] I used to have the same question too, then I learned it from my replica AUG BB assault rifle[/edit]
mercanucaribe
Banned
Oct 20, 2004
9,763
It doesn't make sense to have the line of the bullet and the line of the scope to cross, because then the difference changes with range.. Why not just have them exactly parallel and let the shooter compensate by aiming 2" higher than he would otherwise?
KK
15,903
4
Because bullets drop.
mercanucaribe
Banned
Oct 20, 2004
9,763
And? The arc of the bullet and the line of the sight still only cross at one point (maybe two). Why make the sniper compensate for the bullet's arc AND the different angles when he can instead compensate for the arc and then add a couple inches for the scope's offset?
SVT Cobra
13,264
because the scope itsself can be dialed and adjusted for distances n00b...so once its lned up making an X all the sniper has to do is worry about wind and things not his scope...
mugs
48,920
46
Well for one, if you're shooting a small target at along range and accuracy is important (i.e. competition), eyeballing a 2" difference isn't going to cut it.
That and I think snipers can adjust their scopes pretty accurately on the fly.
skyking
22,786
5,941
Also, he can even make wind corrections on the scope.
