- Jun 30, 2004
- 16,323
- 1,886
- 126
I originally posted a similar question in "NVidia" -- asking for information about the fan wiring of MSI GTX 970 Gaming cards. At first I wondered if the plugs are standard PWM plugs, but without opening my case yet looking at review photos of the MSI card, I can see it is a proprietary wiring plug. It appears to have six or more possible pin positions.
It's my objective to use the PWM signal from one graphics card (of 2x SLI) for controlling a fifth fan to the four on the cards.
Since this is just a single wire for a signal, I'm curious as to how splitters such as the Swiftech 8W-PWM-SPL-ST, Akasa et al -- connect the PWM wires. Any of those splitters only require connecting the standard PWM plug and the signal wire alone to a motherboard fan port.
If all fan connectors at the split end of the splitters are connected at one point to that wire without any other components, I could simply tap in to the PWM signal of a graphics card and power the fifth fan from the PSU through the Swiftech splitter. Simply, I'd have a graphics card controlling three fans instead of the two in stock configuration, without drawing any more power from the GPU card than those original two fans. And, of course, I could add another fan or two . . . Maybe a total of two 80x15mm PWM fans.
