Question How do I use a decimal point in Javescript calculations?
RLGL
2,114
321
Let me start by stating I know NOTHING about programming or what I am trying to do.
The editor I am using is Foxit Phantom PDF.
I am trying to utilize Javescript in a PDF form to perform simple calculations, dollars and cents. When adding all is good. Subtracting is another story, the result is a number with 14 positions after the decimal point. How do I restrict the result to 2 decimal points? The image is what I am using to create the calculations.
RLGL
2,114
321
A quick google search.
Just run this when you are displaying it.
https://www.w3schools.com/jsref/jsref_tofixed.asp
inserting the string :
var num = 5.56789;
var n = num.toFixed(2);
fill_0-Internal
results in:
[ Line: 00003 { TypeError } ] : Cannot read property 'value' of null
======== Field : calculate ========
How do I fix it?
All the methods found by searching result in some sort of error.
MagnusTheBrewer
IN MEMORIAM
Jun 19, 2004
24,122
1,594
var num = 5.56789;
fill_0-Internal
results in:
How do I fix it?
You don't have to worry about decimal places until it's displayed.
purbeast0
53,544
6,368
var num = 5.56789;
fill_0-Internal
results in:
How do I fix it?
I'm not sure why your fill_0-Internal function is throwing an erro.
You asked about setting precision in numbers which is what the solution I posted is for.
Ken g6
Moderator
Dec 11, 1999
16,633
4,562
75
If you need to keep it a number, you can try rounding.
But it's hard to know how much of ECMAScript that PDF software actually supports.
RLGL
2,114
321
Thanks for the input, I found another section of options that allowed the control of the decimal places.
