I currently have Vista 32 bit Home, running on
Intel(R) Core(TM) 2 Duo E6750 CPU @ 2.66GHz
with 2 Gb RAM
I want my computer to use more RAM, so I understand I need a 64 bit OS. I want to buy a 64 bit OS, say Vista 64 bit or Windows 7 64 bit and install it on the same HD. I don't want to buy a new HD b/c I have some preexisting software on this HD that I dont have the original software for a re-install.
question:
1. Can I install the new 64 bit OS without deleting the preexisting OS and data, and just let it "upgrade"?
2. If not, what do I have to do? Partition, formatting?
thanks!
with 2 Gb RAM
question:
thanks!
