How do I turn on Multi Sample AA on my 7800gt?
  • Thread starter Deleted member 4644
  • Start date
D
Deleted member 4644
I cant find it in the drivers. It is on by default? Is it application specific?
Thanks
kylebisme
9,396
MSAA should be simple to find in the drivers, if not you should get the latest ones from Nvidia.
Matthias99
8,808
Multi Sample AA is the default AA mode. If you want to turn on Super Sample AA you will need to set it in the driver control panels. It should be pretty straightforward.
BFG10K
22,709
3,004
The drivers have an AA slider. Alternatively you can get to it through the nVidia system tray icon.
D
Deleted member 4644
Ah ok, didnt know multi sample was default.
