ajaxsirius
I'm using:
i5-3570K using stock (auto) values on Maximus V gene, 2x4GB G.Skill F3-12800CL9-4GBXL 9-9-9-24 set manually in the bios.
I wanted to test for stability before I overclock and was reading the sticky which says to:
I'm not quite sure I'm doing it properly since the fourth window of HCI memtest 4.0 I open sort of hangs after testing on the other three starts. It appears to be working but stays at 0% coverage. I tested this until the other three reached 200%. When I stop the test, the first three stop testing normally, but the last one hangs at "Ending Test..." I tried this twice using amount of RAM to test "2000" and "2048" in each window. I don't have this problem when I test with "10".
Am I doing something wrong or is there a problem with my RAM?
Launch one instance per thread supported by CPU
