How do i tell if my system is really running dual channel?
JEDI
29,391
2,738
cpu = AMD x2 6000
mobo= asus m2r32-mvp
Manual says for dual channel, use memory slots 1+3.
On motherboard, slots 1+2 are same color (yellow), slots 3+4 are same color (black).
Is there a program i can run to test if i'm in dual channel?
ch33zw1z
39,629
20,219
Memtest86+ will say it if your chipset is supported properly
CPU-Z will also tell you this in the memory tabs.
JEDI
29,391
2,738
thx. cpuz says single channel mode.
mem is in slots 1+3 per the manual.
looks like i have to move it to slots 1+2 per the color coding on the motherboard.
sigh
edit:
moved ram to slots 1+2.
cpuz now says mem in dual channel
