how do i share internet connection with a PC and an iBook?
razordog
197
hello
whats the best way to share internet connection between my pc (desktop) and an iBook
the building i live in provides broadband so i don't have any type of cable modem, i think the residents share a t1 or something and currently, i just connect the cable from the outlet to my NIC card and i get a connection and when i want to use the iBook, i have to reach in back and disconnect the cable from my computer and plug it into the iBook
please help me with the following options:
i was wondering if there is such as thing as an ethernet cable splitter that will allow two cables to come out of one outlet? i'm ok if only one computer can be on the net at once for this choice if its available
i was wondering what my options are if i want to setup the network thing, do i need a router or a switch to set this thing up, do i need a new NIC card for my PC? and could you reccommend a good, cheap router/switch for this? hopefully both computers can surf the net here...
also, if i want to go wireless, could someone reccommend good quality, cheap router (or is it a switch i need), the guy at comp usa said i needed a wirelyess, linksys access point? and i'm pretty sure i need an airport card for the iBook (or do i?) and if i go this way do i need a new NIC card for the pc? hopefully both computer can surf the net here too....
thanks for your help
Fallen Kell
520
A switch would be needed in this case. If you want wireless, you will need a wireless router/access point. You may need to get a router depending on how the apartment is setup (i.e. 1 IP per network jack in room).
amdskip
22,530
13
A switch should work just fine. You didn't have to configure either computer to connect like a certain name or anything did you?
Doh!
2,325
Just check the hotdeal forum for a router. For the entry-level routers, the features and performance do not vary much and they all get the job done. You'll be able to grab one for less than $20 (I got one of the d-link routers for a little over $10 after discounts/rebates). Going wireless will bump your budget to about $100 since you would have to get a wireless router and a pc-card (unless iBook already has a built-in feature).
