How do I send the audio from a PC USB Bluetooth headseat to a Bluetooth speaker
Trey22
Sometimes I conduct training classes in large conference rooms and only carry my laptop (BT enabled) and projector with me.
I'd like to purchase a wireless PC headset (RF or Bluetooth), connect it to my laptop, then send the audio to a Bluetooth speaker.
Or is there a RF/Bluetooth speaker that can receive and output the signal from a wireless headset?
There seems to be a lot of apps that will let you use an android/iphone as a mic and output to a speaker. Depending on if you need your laptops audio to be heard then you can route the BT mic (any jawbone like device) through the laptop and then either through speakers or the projectors speakers. Although if you don't have anything on the laptop you want heard you should probably stick with the mic > speaker connection to avoid unwanted sounds ruining your conferences.
I wasn't seeing any mic's that would act as a host bluetooth device and connect to speakers. This probably has to do with one side of the bluetooth connection needing a UI. Neither the mic nor the speaker would be able to select each other for pairing purposes.
