- Feb 22, 2008
- 2,846
- 4
- 81
I gave my old computer to my dad a while ago to hook up to his dlp hdtv a while ago. The TV really doesnt support that many resolutions, so setting this thing up is a bitch.
Usually if you have a problem with the res, the TV will say something like "mode not supported" so youll have to hook up a 2nd regular monitor and then set the correct res for the hdtv and then disconnect the small monitor.
Well he got a pretty nasty virus on there so i reinstalled windows and had to go through this process again. While i was setting up the HDTV i was going though different resolutions to see which looked the best, and somehow it now thinks its displaying fine on the hdtv.
I now hve this problem: when i boot up with just the HDTV plugged in i get nothing on the screen, if i try plugging it in after im all booted up with the smaller screen both screens go out because in its memory i guess it thinks the HDTV takes priority, so theres no picture.
So basically i just need to wipe out the saved settings somewhere on the computer. If i can do this, by default it clones screen 1 (the small screen) and then i can correctly set it up from there.
Hope that made sense, thanks in advance for any suggestions.
