How do I rename an android project?
pcnerd37
944
Here is the deal. I have an android project that I initially started with the code from the notepad tutorial before building on a ton from there. My project is essentially done and I am ready to submit it to testers before putting up on the Android Marketplace, but I have a problem. Since it was built on top of the Notepadv3 code, that is what it is named as. I can't seem to figure out how to change the name of the app so my name will show up in the android emulator and at the top of the first screen of the application. I have renamed the project folder in the project explorer (Eclipse for those that don't know) but it seems to have had no effect. Can somebody tell me where I need to go to change the name of the application so I can get this program out? This is the last thing I need to do to get it out. Also, if anybody is interested in testing it, PM me.
pcnerd37
944
Nevermind, after several hours of playing with it I finally figured out the problem was in my strings file.
