how do I remove my rear speakers in my 2000 Honda Accord 4 door?
slugg
4,723
80
i've searched everywhere and can't find an answer. Any ideas?
RagingBITCH
17,618
I've never removed it from a 6G Accord, but have done it on a 5G and 7G. What's the hard part about it? Should be 4 bolts that go in from the top into 4 holes in the rear deck. Also unplug the speaker adapters, pull out. (Might need to remove the grilles on top, have no idea if the 6G's have grilles that are mounted with screws on the bottom)
slugg
4,723
80
well i figured it out... there are two screws and a clip that need to be removed for each speaker grill. The problem was finding those two screws - they were pretty well hidden.
I'm enjoying my Alpine Type-R 6x9's right now... I'll do the front speakers tomorrow (also Alpine Type-R, 6.5")
