How do i make sure my flash drive is wiped
amdskip
22,530
13
Honestly I wouldn't sell any of my flash drives on ebay. I've had a few very personal items on mine and it's not worth someone stealing my identity with recovery software. Sell it to a family member or someone you can trust instead.
xSauronx
19,582
4
fill it up with garbage you dont care about and delete *that* ?
id think you could find some software for free with google that could write garbage to it without a problem
gsethi
3,457
load it up with PRON ??
All you have to do is rewrite over the entire drive (rewrite a few times just to be safe).
TheGizmo
3,627
low-level format it... then load it up with random non confidential data, delete it... repeat these steps 3 to 4 times and you will not have any problems
jadinolf
20,952
Then, hit it with a hammer.
TheGizmo
3,627
Originally posted by: WiseOldDude
10 minutes in the microwave on HIGH, then cool it off in a sink full of cold water
5 bux says it will still work and have the data on it
Kirby64
1,485
Electronics work well after being doused in water? That's new to me.
Bootprint
9,847
Flash drives can survive being left in your pocket and going through the wash.
Kelvrick
18,422
I don't think the electronics will matter unless you plug it in when water is still in there. You might have some issues if the water dries and the minerals in the water connect the leads though.
xanis
17,571
8
Reformat the drive. I think most thumb drives are FAT file systems, so just reformat it in Windows.
pcnerd37
944
I saw a review of a Corsair Flash Voyager where they put it in boiling water and ran it over with their car and it still worked.
Bootprint
9,847
That'll only rewrite the FAT and leave everthing else intact, at least it does with an HD.
We had a bunch of HDs at work a few years back that we needed to be clean. A few were formated but then we used a disk editor and could still find all the data intact. We ended up using DBAN on the lot before sending them out.
Luthien
1,721
Bleh, just do like already said and load it up with crap format it and do it again a few times. Or buy some software that does it for you.
Jeff7
41,596
20
Originally posted by: MercenaryForHire
DBAN it, then fill it with porn. :p
- M4H
Mixed music flash drives? :D
I suddenly want to write a CD-erasing program, and it shall be called, "Oh snap!"
Kirby
12,028
Does DBAN format all hard drives that it detects? Or can you choose what drives? From the readme it sounded like you boot it on flashdisk or floppy and it wipes everything.
