how do I make a fan controller?
iskim86
Banned
Jul 6, 2001
1,802
www.isaackim.org
I just want one fan connected to a pot so I can control the speed. how do I do this? I have all the equipmnent, I just don't know what to wire to what
ps. thanks
phisrow
1,399
The most basic setup is 12v(yellow wire on PSU) --- Potentiometer --- Fan --- Ground(black wire on PSU).
That's pretty inefficient, but it'll work just fine(assuming that your potentiometer has a high enough rated wattage to deal with the heat it will be generating. Never a bad idea to give it some airflow and/or direct contact with case metal).
There are more sophisticated designs; but this will work for a start.
