How do I load a ISO without using a disk?
Cappuccino
Sorry noob question from a noob like myself 🙂
Basically I'm downloading a game on ******** and it requires to burn onto a disk after installation but I do not have a disk, so I was wondering if there's a way to load the game without burning onto a disk? Really appreciate the help! 😀
I use PowerISO
PowerISO is a powerful CD / DVD / BD image file processing tool, which allows you to open, extract, burn, create, edit, compress, encrypt, split and convert ISO files,
and mount ISO files with internal virtual drive. It can process almost all CD / DVD / BD image files including ISO and BIN files. PowerISO provides an all-in-one solution.
You can do every thing with your ISO files and disc image files.
I usually just use something like Winrar/7-zip to unpack it to a directory and install from there. Have done this a lot with images off MSDN.
Use Virtual CloneDrive, which doesn't access the internet, unlike Daemon Tools.
u can opt out of using daemontools search when you install.
(did they remove that option?)
i assume ur talking about that?
i dont see it accessing the internet unless u opt'd in for the search.
i read something about daemon tools phoning home with the filenames of the images.
