- Oct 23, 2002
- 6,294
- 171
- 106
Ok I have an X2 5000+ BE currently running at 3.1 (15.5x200) @ 1.4 (is this too low?).
Anyway core temp reports idles of ~25C and Abit EQ reports 40-45C.
My system fails SP2004 after like 10 minutes, but the temp log for core temp never goes above 35C. I do however get a warning beep from one of these damn programs...
Also, does anyone understand how to use Abit EQ? The CPU fan speed always reads 50% and the system volume never changes so obviously the fans are either maxed 100% of the time or just at some random percentage the whole time. I thought they were supposed to vary depending on temps/load. My bios has options for target temp and tolerance which I understand, but then has options labeled start CPU fan control (percentage) and stop CPU fan control (percentage), same for 1 system fan. As far as I can tell, neither do anything.
I just installed a Blue Orb II and the fan speed reads 1700 in the bios, I cant figure out how to change it.
Thanks!
Edit, my system at stock fails after similar times, and the temps read exactly the same as they did at 3.1.
Thanks!
