how do i keep my 6" timberlands clean?
Amplicom
99
I got the toe part on my left boot dirty from motorcycle riding... how do i clean them?
Thanks!
FoBoT
63,084
14
fobot.com
linky
<< Keep them clean. When you buy your boots not only should you walk out of the store with waterproofing material, but you should also leave with an appropriate cleaner. There are a number of products on the market today that will work on either synthetic or natural materials. Start by banging your boots together to get the largest amount of dirt out of the lugs. Then, take a stiff nylon brush and brush the boots to get the dirt off. If your boots are still dirty, get a damp cloth and wipe the dirt away, be careful not to soak the leather. If you are removing volcanic dust, use a vacuum and stay away from water. Once you have cleaned them up follow the directions on your selected boot cleaner. After cleaning your boots, you should waterproof them again. Wait until they are fully dried from cleaning before repeating that process.
