How do I keep Catalyst Control Center from loading upon bootup?
Just uncheck the CLI.exe file (it should be in the ATI directories) from the Startup tab in Msconfig.
Cool deal - thanks! Ok, one more question about msconfig - after I made the change and then rebooted, msconfig was in selective startup. Is this generally what I want or do I want normal startup on the general tab in msconfig? Thanks Noema!
Selective, that's the custom config.
If you choose normal, all the drivers and programs on the startup, WIN.INI and BOOT.INI tab will be checked (the default configuration will be set) and loaded upon booting.
