How do I keep ants from invading?
Status
Not open for further replies.
shortylickens
80,287
17,081
If I drop a crumb and clean it immediately the bastards are crawling all over the place an hour later.
We've got a pest control dude coming this friday but until then I need to slow their roll.
Would cleaning up with vinegar help? Rubbing alcohol? Bleach? Ammonia? (Not at the same time)
shortylickens
80,287
17,081
is there some sort of decoy I can put outside to distract them?
Should I find the ant nest hive and pour gasoline in there?
What if I released a hundred frogs and let them gorge?
mizzou
9,734
54
spray exterior with a bug killer. You may need to clean tye heck out of your floora to erase any preexisting chem trails left by ants
paperfist
6,539
287
www.the-teh.com
I had the same problem. Bastards were everywhere! Even under the mouth wash bottle.
I used this:
http://www.walmart.com/ip/Raid-Double-Ant-Baits-4-ct/11046003
They say not to kill them as it could be the scout and if you have those baits it'll take it back to where they came from to kill the colony. Took a few days but they worked.
Tried 3 or 4 other traps and the ants laughed at them. Tried bleach, rubbing alcohol, dish soap in water, borax. None of that crap worked unless of course you sprayed them directly, but a few hours later they were back.
Status
