how do I install XP pro without using a cd drive?
bdjohnson
748
the cd drive on this laptop always gives tons of errors when I try to install xp and I know the disk is fine since I have tried multiple disks (both of which have worked flawlessly on other machines) and it gave similar errors. I have a nic for this machine as well as a floppy drive. I just don't know how to go about doing a network install. Thanks.
bdjohnson
748
Originally posted by: PhasmatisNox
If the CD drive can't handle it... can the laptop?
I'm not sure what the problem is exactly with the drive but when I tried to transfer large files with it the computer crashed. The machine is a pII 366 with 128mb RAM and 5gb HD so its fine.
Frew
2,550
Originally posted by: ucdnam
you shouldn't be running windows xp on a pII 366 laptop with 128 mb ram.
agreed. 2000 is your best bet or you may even want to try Linux (if your up to it).
38
hey man, i recently installed xp pro on a 366mhz HP machine with 192 megs of ram. it ran but slow put win2k pro on it, it will run that fine.
tami
11,588
your problem may be the harddrive that you're trying to install XP onto. i had a similar problem -- got errors every time i tried to install the OS. it wasn't the CD-ROM drive, i'll tell you that.
bdjohnson
748
I've had it on this machine before. It runs just fine with all the visuals turned off. Just as good as 2000 plus more features.
cronos
9,380
26
101
i installed XP Pro to 15-20 machines over the summer. about 12 of them are P-II 400 and there rest are P-II 366. the RAMs varied from 128 -256 MB. they run just fine.
