how do i install freezer pro 64 facing rear on DFI ultra D?
MrX8503
i read somewhere that the ac freezer pro 64 when installed on the ultra d it faces towards the pci slots. How do i switch it around so that the fan faces the rear exhaust? Also when its facing the rear is there enough clearance for the ram with heat spreaders?
To turn the Freezer Pro 90 or 270 degrees, you have to remove the screw holding on the retention lever, pull the lever/lug bracket off, pull the rest of the pressure spring out and reassemble everything so that the fan is pointing in the direction you wish it to. It should be on the direction sheet as well (although not very well explained).
