Start by changing one of the values of the Registry Key specified below to any number 0-9 or character A-F. Changing any character will do - it doesn't matter which one you change or what you change it to.
Hive: HKEY_LOCAL_MACHINE
Key: Software\Microsoft\WindowsNT\CurrentVersion\WPAEvents
Data Type: REG_BINARY
Value: just change one of the entries as mentioned above
What this will do is deactivate the copy of Windows. Now click Start, Run, and copy the following into the Run box:
%systemroot%\system32\oobe\msoobe /a
This launches the Product Activation Wizard. From there you can choose an option such as calling a Microsoft representative, and select the Change Product Key option.
