Hello,
I have a Microsoft MN-500 wireless router that I am using and I would appreciate some help identifying if I am getting appropriate speed levels from the device to my wireless pc. My ISP is Comcast cable.
The issue I am noticing is my wireless speed may be getting limited or throttled from the wireless router itself. The reason I say this is when I run a speed test at speedtest.net, my speed starts at 1 Mbps, then jumps up to 2.30 - 2.50 Mbps and stays at that exact level for the rest of the test duration. Then my upload speed is usually higher than my download speed, at around 2.7-2.8 Mbps. My roommate is connected to the router using a wired connection, and he is getting between 6 and 7 Mbps test speeds.
With the 802.11b standard I should still be able to achieve that 6 or 7 Mbps rate, correct? (assuming my signal is strong, I am using a channel that is not overused, etc)
Are there settings in the router's management that could possibly be set incorrectly so that the router does not allow the full speed to be utilized?
Thanks.
Thanks.
