Inputs:
.... The line level
inputs are used to connect pre-out or preamplifier outputs directly to the
subwoofer amplifier?s internal crossover. These inputs are summed to
mono. This is the preferred way to connect the subwoofer amplifier. If
you have a mono line level signal from a ?Pro Logic?or ?Dolby digital?
receiver use the right ?red? input. ....
Originally posted by: mcveigh
any difference with the splitter?
Originally posted by: ElFenix
yet another problem that would be solved by reading the frickin' manual
