Originally posted by: Krueger81
why don't you use get a TV tuner card for your PC. it would be a lot cheaper and a lot easier to hook up.
Phil
Phil
tv cards don't generally have 1280x1024 support, unless you pay a lot
Phil
Why do you need 1280x1024 support? I mean, tv's res. is 640x480 (or close to it) so, unless it could do HDTV, why bother?
Phil
Phil
Originally posted by: Apex
That should work fine.
Computer -> DVI -> LCD
TV Tuner -> VGA -> LCD
LCD's do scale. The reason for getting a tuner box that can output 1280x1024 is if the tuner box's scaling of video up to 1280x1024 is better/cleaner than the LCD panel's. If so, then it's better handled at the box, if not, then it's best to feed native rate into the LCD and let the LCD handle the scaling.
So what are you saying? Will this box improve my video quality or can I just get a Leadtek TV2000 PCI or whatever it's called at Newegg for $20 less and let it do the same thing?
