How do i group icons in System Works 2002?
moosey
1,331
On the left side of the start menu, my 3 norton system works incons are usually grouped into an "N" icon. They are not right now. How do I make them? I have winxp.
corkyg
Elite Member | Peripherals
27,370
239
In version 2002, just recently updated (live update) the icons are usually controlled in NSW's OPTIONS menu. I like to get all of those things out of my tray . . . and I place a single icon for NS's "NMAIN.EXE" - that is the only one needed to access all three program elements. Then if you right click on it, there is a menu item called "Appearance." That will let you customize or use the default icon setting. I like to customize mine.
